Hello - I have looked at the other posts on this and have not found the answer. When I start if there is a slight bog and it does not seem to get to quite the top speed but other than that things run pretty good. After about 20 minutes it gets a lot worse. You have to feather it to start off from a dead start or it just bogs out. Once you’re on plane and about half throttle it rides ok but from about 75% of throttle and up it really starts to surge constantly going up and down.
I have had the carbs and fuel system professionally rebuilt –no change.
I replaced the check valve a fuel release valve - no change
Any ideas on what to look at next?
Thanks
Thanks
