cruisertom
Ok I am narrowing this problem down, I think. When I choke both carbs with air filter covers it will idle but rough. Then it will go all the way up to 7k rpm and stay there till I shut it off. All my lines are tight, where can it be leaking from? I had to remove the intake and rotary valve housing to remove the carbs to rebuild them, could a vacuum leak develop from the rotary oring? Where do these things get vacuum leaks?
