94 xp fuel gauge and vps inop
dereck22
i just bought a 1994 xp and the fuel gauge, and vps do not work. Is there a fuse box i could check for these or any other ideas on where to start my search?
I have a 93 xp with the same problem. Just got to working on it the other day and found the VTS works when I jump it straight to the battery and switch leads to change direction. Also noticed there is a steady draw of around 4 volts on the plug coming from the box, the was a nice day so i stopped wrench'n and went riding. Going to work on it again after the 4th.
Hope this might help you a little
im kinda in same boat with my 94 xp but my gauges work and the vts dont. when i hot wire it the motor goes up and down fine. when its hooked up normally my vts module in the gray electronic box clicks when its spo 2 work but nothing happens. Also remember vts dont work unless you turn the motor over then it will work for a few seconds. you have to start it up to get it to continusiouly work. fuel gauge is the same.
