I got this SPX after it was sitting for a lot of years. It's all working except the gas guage. I got the baffel out and the float comes out the bottom with no problems. Everything looks clean and looks like it is functioning properly. I think to test the guage I put 12 volts across the leads coming off the baffel and the guage should go to "full". Is this correct? If the guage does function after this test what would be the next thing to test? Is there a fuse involved somewhere? Should I see if the float actully "floats" as it comes out and I can test that as I heard that they can become "gas logged". Any info would be great as after I fix this one I need to fix my 97 GSX with the same problem. Thanks.
I just realized I should short the leads to read a full tank not put voltage to it. Also I think I read the fuse may be in the baffel? Is this correct? Thanks
