soccerdad
So it sounds like your switch is dead. These old skis just have a switch that is pushed down by a lanyard right? IF so, then maybe that switch is bad. FOR TESTING ONLY you can bypass that lanyard switch. Then push your start button again. If that does not work, you can then hotwire the thing to see if it will crank. To do that you would connect 12VDC to the small terminals on your solenoid. Not sure how yours is wired now. First, use your meter and see if you have 12V between your + or - terminal on you battery and either of the small posts on your solenoid. If you get 12v, then run a wire through a switch from the terminal on the battery you were one when you got your reading to the post on the solenoid that you were not on during your 12v reading. Switch your switch and it should at least click. and Hopefully, start cranking.
