OK I know wearring wearrring wearring.
92 gts starts fine issue is 3/4-WOT sounds feels like i'm bouncing off the rev limiter same noise if you spin it out.
there is no loss of top speed. or noticeable acceleration change.
same speed and acceleration as our 93 GTS same engine noise/pitch at cruise/acceleration only difference is on the 93 3/4-WOT yields not more speed maybe a little deeper growl.
so what can I look at? MPEM/rev limiter? Impeller/wearring? or carb rebuild?
MPEM taking the ski out of storage last week needed to open the brain box to replace the 15amp bullet fuse. other then fuse holder was a little melty it looked really clean no water evidence. (this is the old mpem with 2 relays)
