i bought a 1996 seadoo gtx with the engine apart. ive gathered up most of the parts i need. i was going to send counterbalance shaft in for an exchange,but when i received the gasket kit thye seals were in the kit.i marked and measured the gear location ,pressed the gear off and polished the seal surface in my lathe.i then pressed the shaft on EXACTLY where it was before. i then put in centers of lathe and checked with dial indto make sure it was true. IS THIS OK or does anyone usually touch these. would not think of touching a crank shaft or anything but this seemed fairly simple
