I have a 1996 GSX 787 and I want to verify if the mag is bad but I'm not sure how to measure the voltage on the yellow wires inside the gray box. I pulled the connectors back so I could clamp the multi-meter leads to the yellow wires.  Where do I connect the leads for the test?  Here is what I did.
I placed the leads on the (3) yellow wires, alternating between the wires while revving the engine. I got about 7 volts reading on the meter no matter which wires I swapped to.
Next I placed the negative on the ground in the gray electrical box and and placed the other lead on each of the three yellow wires. Basically the same 7 volts.
I tested the red wire and grounded the black lead and the meter read 13.2 volts when I revved the engine. Kinda of confusing to me. I was expecting battery voltage on the red and black wires if the mag wasn't putting out. Help is appreciated.
