digital sol
Working on a full 97 gtx rebuild and was wondering if these rave valves are ok? This engine was purchased used with aprox 60 hours on it, the ski has around 300 hours on it & this is the third motor for her.
I am fixing/replacing lots of problematic items and I pulled the raves for cleaning, i used some chemical stripper to remove most of the carbon build up but wanted to get your opinion and see if you think these valves need replacement. They have some small pitting and/or scratching on them. They were really, really gummed up when I pulled them. I am trying to stay on a budget as I also have to
-rebuild carbs
-fix fuel tank issue
-fix 12v low issue
-fix speedo issue
-clean/paint/touch up several items
-replace floor mats
and various other things
Gave the housings some color. I plan to keep the red bellows as they are not torn or anything. I was going to keep the spring on the larger side and zip tie/metal tie the bottom portion to keep them in place. That or I heard using an oring on the bottom works wonders as well.
-rebuild carbs
-fix 12v low issue
-fix speedo issue
-replace floor mats
