seadoodoopartsofcf
I don't know if this fix has been addressed, but the RFI ski's are prone to plug fouling. I've found that flushing the ski every-time I use it and adding lucas fuel injector treatment to the gas keeps this ski running tip top with absolutely no issues. The RFI'S are susceptible to moisture which the fuel injector cleaner help with, and the crank coolant passage is such a bad design that it needs to be flushed absolutely everytime you take it out, no matter what conditions you run it in ( salt, fresh, sandy, etc.) Hope this helps someone out, because most people say the fix is to change the injectors, try this before hand and it might work for you as well..
Regards, Jim
Regards, Jim
