I have read a couple threads on winterizing the 720 with plugging the hoses to hold the antifreeze in and have a few questions.
Is it really necessary to keep it filled with antifreeze, that is if you fill it and it drains out, what is left to freeze and ruin the engine?
Can you just blow out the water with compressed air?
What is going to stop the antifreeze from seeping into the engine when it's not running with exhaust pressure to keep it out of the cylinders and crank case the way it does if you run it on the hose and the engine dies?
