Super new to this engine. After removing the intake assembly the piece of sheet metal that spins on a splined shaft ( I belive called the rotary valve), that allows air fuel mixture in to the cylinders. It was torn about half way around from one side and the block face and cover that this sheet metal spins between had gouges in them.
Here's the story...... I was running for about two or three minutes full out and the right engine just stopped. Turned over, but would not run. I took the cover off and this is what I found. Full tank off sea doo oil in the oil tank.
What happened here and I need direction now.
