I just got back my rebuilt 657x engine from FullBore and am about to install it in my 1995 GTX
The flywheel and rotary valve cover are on and were installed by FullBore
I am going to install as much as I can before taking it to the dealer so they can use the alignment tool to make sure my motor is properly shimmed and aligned with drive shaft.
My question is how much can I install before without impeding access to the engine mounts. I assume I can't install the exhaust but can I put the carbs back on? and hook up all my oil lines , electrical etc.
Any other tips? I was told to install the started before the engine support plate
FullBore gave me new gaskets for the install should I use gasket sealant on any of them if so what type and which gaskets ?
