Im new to this Can I get some help on my 94 SeaDoo SPX as soon as battery is connected 5 amp fuse keeps blowing on the mpem and I remove the yellow and tested and it blow then the red and yellow on the redrectifier and it's still blowing ?
Thanks GGuillo ill look in to that one more question would I have to get the dess program if I got a new mpem then
The OP is working on a 94' SPX but even then the HX did not get DESS until 1997.The HX has the DESS post, but it the system is not active in the MPEM I believe.
There are so many HX posts floating around right now that I’m getting mixed up... Sorry about the out of place information!
I can't really say has no gauges the only thing ne it has is the gas gauge
its if you had the throttle about half way
Normal to see about 3000 RPM out the water, in the water it'll drop in half to about 1500. You could buy a small cheap tach to check it, some people do on skis that don't have a tach. Or you could just put it in the water see how it holds an idle and putts along.
Any recent work on it? carb work off the ski? You may have a vacuum leak if the idle is having a difficult time coming down. Did you try to adjust it? How is it under load in the water? Try to attach a video so others on here can get an opinion since you don't have a tach on it to tell what the RPM is. 3000 RPM is fairly high but normal out the water...a video will tell if it's much higher since 3K RPM what most of us are used to hearing.
Blipping the throttle and it hangs and doesn't drop quickly after you've tried to adjust the idle down is typically a vacuum leak. Bad seal at the carb, pto seal, etc.
Take it on the water and see how it feels, from how you've explained it, it sounds good.So I adjusted the idle and it sounds good and I hit the throttle and title came back down but I also take a video of it and I can't seem to post it is there a certain way to do that on here
Will do going this Sunday
One more question what do you recommend for oil it has oil in it rightnow dont know what tape it is
