I'm confused. I was in the 05 4tec shop manual vol.3 looking at fault code table(pg.87). Code P0118 is a temp sensor code. The table says you will have a warning lite flashing, info center will display CK ENGINE. What I don't understand is in the "LIMP MODE" column is a "N". I have to assume the "N" stands for "NO" meaning the engine would not go into a limp mode.
Am I reading this right? Is the manual correct? Seems to me that any overheat situation would cause a limp mode activation.
Thanks, Dawg
Thanks, Dawg
