darren shumbo
I just had a customer come in with a Seadoo rXt 300 with 5 hours on it that had a gradual loss of power and rough running problem. It seemed like water got in the fuel system somehow and was causing the problem....Sure enough, the tank had a lot of water in it and the engine injected water through the injectors...Didn’t
seem like a big issue and after many hours cleaning everything out it still wouldnt start and run right . Against normal judgement on such a new ski, I did a compression check and found all cylinders at 60 psi, verified with 2 sets of gauges.It seems the ski was not winterized properly and the water being injected into the cylinders washed the oil off the rings and cylinders and destroyed the engine...the ski is brand new...what a shame to have to pull the engine and start over...
