I i have just bought a 2015 gtr215 a week ago and havent been out on water yet due to the cold weather here.
Now today i did an oil level check while it was level on the trailer and it was just above the minimum mark.
I had a look in the manual and did the same level check after i ran it with the hose attached for about a minute then shut down and waited a few minutes. The oil was now well below the min mark. I checked the level several times figuring it might come up when it settled in the pan. Nope it stayed below minimun. So i added about 2-3 dl of xps semi syntetic and its now just between minimum and half.
Is this normal?
Should i add more?
Ill be checking tomorrow without fireing the thing up to see if its above the first check again..
Any adwise to a first time pwc owner?
Is this normal?
Should i add more?
