2014 GTI 130SE stator and rectifier
Marley2709
Hey guys, I'm just trying to figure out where everything is in my sea doo. I think I might be having a charging issue and I wanted to find out where the stator and rectifier are located in case I need to replace them
sorry, I can't figure out how to link a fiche without it coming up all screwy...
front of the engine.
there are some good writeups i've seen on other sites... pm sent.
one suggested to check the fuses as well, maybe something simple.
Thank you so much I appreciate it. I bought the jet ski used with only 16 hours on it and I took it out two weekends ago and it ran fine all day. I took it out last Saturday and I got the message low voltage and the battery died. I checked the fuses and everything's good I'm just hoping maybe it was a battery issue since the seadoo sat the dealership for who-knows-how-long without it being on a tender
< not even close to a 4tec expert, but as I stated in the other thread, appears to be a charging issue, other's with more experience should chime in and either confirm i'm on the right track, or call me a dumbass. 50/50.
both work together I believe.
flywheel spins, stator creates ac current, rectifier converts current to dc, then charges battery.
(or something along those lines)
your rectifier might be easier to access and visually inspect.
