2012 Wake 210 (310 hp) Drowned Mode Throttle Accelerator Sensor TAS location?
99spxman
Hello all,
long time SEADOO owner, just recently purchased a low use 2012 Seadoo Wake 210 sportboat for the family this summer. Im in the midst of doing my first Winterization and need some assistance. I completely understand the process of doing the winterization in the owners manual, but cannot locate the TAS sensors to put the engines in DROWNED MODE. Can someone tell me where to find these? Thanks in advance for all your help!
Here you go.
To activate DROWNED MODE, proceed as per following
steps.
1. Ensure engine is OFF (both engines if applicable).
2. Install the tether cord on the engine cut-off
switch.
3. Select idle and neutral positions.
4. From the driver's console area, move the throttle
accelerator sensor (TAS) to the wide open
throttle position (WOT) and HOLD.
NOTE: For TAS access and identification, refer to
INTELLIGENT THROTTLE CONTROL (ITC) subsection
Lift up the seat back on the starboard bow seat. Remove the black fabric curtain that covers up the opening to the console and helm. At the very base of that opening, you will see the tas sensor set. Push the sensor to wot, and hold it there with a tie wrap. Make sure the throttle lever is in neutral and crank the engines.
Thank you Coastiejoe & go_panthers. Ive read the owners manual front to back 2 times looking for the subsection they reference for the location of the TAS.. guess its on another publication. She will be winterized today! Thanks again!
