WaTeRMaNiaC407
Hey Everyone,
Earlier in the year I went to turn on my NAV lights at the helm and they didn't come on and the dash illumination was not working either. The toggle switch itself has an LED indicator when it is on and it was illuminated. I turned the switch off and went to grab a meter to check the fuse and before I did anything else, I flicked the switch again and the lights were all of a sudden working again.
Once they started working they were fine and you couldn't get them to not work.
This happened one more time a couple months later and then they started working again almost right away.
This morning, I was checking things over on the boat again and decided to check the NAV lights and it is the same problem. LED lights on the toggle switch, fuse is good. (If the fuse is removed the LED won't even light on the toggle). This time I can't get them to come back on.
I am not quite sure how to troubleshoot this because I know the switch works, the fuse is good and I know that the lights are not burned out. The service manual does not seem to be much help in this area either.
Any ideas on some first steps? The last thing I want is to be hanging out on the water until dark and have no lights.
