Sam Dudley
Hi guys,
Been racking my brain over this one for a few weeks but took the ski out ran fine like normal then after about a half an hour of use turned it off and then wouldn't turn back on. It is throwing the P1502 TOPS fault code.
So I've been through all the fixes in the shop manual and everything seems to be ok?
One more thing, when putting the DESS post in I do not hear the two beeps that you normally hear and when I first put the key on the relay in the fuse box goes mental clicking very rapidly and then stops after 10 seconds or so.
After a while it will throw the fault code, prime the fuel pump then go to starts a small kick over then throws the code, beeps and won't start.
Anyone have any ideas on this?
