2011 GTI 155 SE Sea Doo
Yellowfin13x
The manual says its 15.9 fuel capacity as well as the dealer. When I bought it the tank was empty filled it up 12 gallons max. Ran the tank empty filled it back up 12 gallons again max!Is there something I am missing here? Also during the break in period will the machine give me full power or is it after 10 hrs? Any help would be much appreciated thanks.
HI, Yes the operators manual says 15.9 gallons. Are you actually running down to nothing or just when the gauge says LOW. If you have a reserve system then that will keep 2-3 maybe even 4 gallons in your tank for emergencies.
The power the machine has is up to you. The more you press the throttle the faster it goes, even during break-in. Unless you are using a learner key, which I think is a different color, but not sure. You are on your second tank so you should be ok...how many hrs on the motor now?
Don't run WOT until at least 10 hrs or whatever your manual says.
Right now I am real close to 10 hours. Yesterday when I hit about 9.5 hours I opened it up for about 5 sec. Trying get an idea of the top speed. Just when the gauge says low so thats cool 3.9 reserve.
