Hello,
I have a 2010 RXT-X with about 75 hours on it (I know, I barely use it). This week after hearing a "shrieking" sound at idle and weak power forward. I was towed in to shore and took it to my local dealer. He discovered a fair bit of water in the hull (carbon seal?) and upon starting it on the trailer noticed the sound, which quickly went away. It turns out the splines on the prop shaft have stripped, requiring a new shaft and related parts (about $1,500.00CAD). I've read elsewhere that this part was a flawed design but that there my be other issues that are contributing to failure (engine alignment, pump mounting, etc.).
I'm a bit lost. Does anyone have direct experience with this failure and a fix that will last? I'm coming up on 100 hours which will necessitate a supercharger overhaul (another $1,500.00) and don't want to face another shaft repair after that.
The dealer has indicated that he is going to try and get some help from Sea Doo on the repair cost. I won't hold my breath though. The funny thing is that my low hours have put me at a disadvantage. I bought this Sea Doo in a promotion with a one year warranty and 4 years B.E.S.T. added to it no charge (expired in May 2015). If I'd put more hours on it, it would have failed last summer while it was still under warranty.
I'm considering just trading the unit in on a new one.
Thoughts?
PS This is my 3rd Sea Doo since 2003
1. 2003 GTX 185 HP - engine fault at 11 hours, traded at the end of the season when the dealer could find the problem quickly
2. 2004 GTX 185 HP - no problems through 2010, traded at the beginning of the 2010 season
3. RXT-X 260 HP - current ride with damaged driveshaft
Thoughts?
