2010 RXT-215 going into N
CF-RJK
My 2010 RXT keeps flipping to Neutral when at speed. If I keep it below 50KPH it seems to do it less.
Recently had issues with IBr, ended up with a bolt getting stuck on the gate. Was fixed and rescured
Any ideas of what it could be? There are no lights or error codes with this.
Sounds like water pressure on the gate at speed is causing some issue in combination with the old stuck bolt issue. Something got bent or stripped. Download a service manual and check condition and free play in gate. Also on port side where the ibr gear thru hulls into the gate might have partially stripped.
