2010 Challenger - Where to add second (house) battery?
I have a 2010 Challenger 210 se and aside from mounting a battery on the opposite side of the starter battery I don't see many other options.
A smaller profile starter and house battery that will fit in the area where the original starter battery is?
Mount house battery under seat which is next to the starter battery and drill through for wiring?
A two in one starter/deep cycle battery?
I am in need of the house battery for an upgraded audio system.
See current setup here
get new base for twin battery , you can connect it to existing bolts , i did it on mine challenger 230 , plus i changed from group 24 , to group 27
get new base for twin battery , you can connect it to existing bolts , i did it on mine challenger 230 , plus i changed from group 27 , to group 31
Do you happen to have any pics? To me it looked like a tight spot to fit two batteries where the one stock battery is. Thanks
new base bolted to existing holes , plus i did some silicone around it sits strong on its place .
awesome, thanks for the pics. I will check out the tray you sent. Also, funny you mentioned the lithium, I was wondering why I have not seen any mention of them. I just switched to lithium on my jetski.
i mention lithiumFE cause it much lighter and much powerful and fast charging . In Canada we dont have starting lifepo4 or it cost 1K$ in USA you can get it for reasonable price
Yea the lithium are expensive. I was looking at this for a house battery (OPTIMA D31M)
Advance Auto Parts
Can I used any starter battery in conjunction with this battery?
Will this tray fit into a 2008 challenger 230se? I have a normal truck battery that I was going to put in and I would like to do this exact thing. Where do I put the ACR??
Thanks.
what is ACR ?
Automatic Charging Relay, like they have in the Blue Sea Add a Battery kit. My understanding is that they will charge both batteries appropriately instead of one taking more than it should leaving the second battery without a charge.
OMG :)) got you . on mine 230 i installed double base and it fits into existing holes for single battery base . If you notice on my picture top left corner there is ACR . I took plastic cutting board , cut size i need and screwed to the wall ( there is internal walls for that ) dont mixed up :))
awesome, just the inspiration I needed! What did you do with the battery cutoff switch up front? Did you swap to a dual battery switch or does the ACR take care of that for you? I am not great at visualizing. I am new to this!
Edit: How did you wire up the "house battery" to your accessories??
yes i did new one for twin battery , make sure you get with soft switch between batterries to protect alternator/generator
IMG_2259.jpegIMG_2270.jpegIMG_2261.jpegI added a second battery to my 2012 210 SP. I removed the current battery tray and built a platform out of trek decking and then mounted two group 31 battery trays to it. I placed them close together and turned them 90° to keep the bulk of the weight on the fiberglass battery platform. I also changed out the battery switch, added a relay to isolate the batteries and added a 2 bank battery charger. It was a pain in the ass, but it came out awesome.
