2010 Challenger 210 coolant in engine oil
Richie345
Premium Member
Premium Member
I keep finding water/coolant in the engine oil of one motor. Mechanic pressure tested the radiator, intercooler, manifold and oil cooler and all was good. He suspected that the motor ingested coolant from the water/oil pump as there is a gasket in there that keeps the oil separated from the coolant. Can anyone help?
Change the oil cooler
It may show not leaking during pressure check but leaks when oil is hot
The places it can mix is
Oil cooler
Cylinder head (gasket)
Oil pump
PTO to engine block gasket
Failed intercooler
