Spyder7892
Guys,
I am having an issue with my port motor on my challenger 210. This is the first time I have had it on the water and bought it as a bit of a project so I assumed I would have a few issues to sort out. Both motors fire up fine and rev fine on the trailer with water attached. When put in the water both engines fire up and idle fine but when I go to take off, the port side motor cuts in and out (continues to run). It seems to idle fine but will sometimes take off just fine with the other motor but every few seconds it will drop rpms and then take back off again and repeat. I am getting intermittent P1106 and P0106 codes but they seem to come on and cut themselves off. The motor is just constantly cutting in and out, but when it is in it seems to run just as strong as the other motor.
Thanks for the help
Thanks for the help
