Hey everyone,
Hope you guys are having a great new year.
I am having an issue with my '09 wakepro. There appears to be an oil leak, when the jetski is running and it looks to be towards the rear of the craft. I did quiet a bit of reading and research and the consensus points toward a bad seal on the oil tank but I do not think that is it because at the front of the engine it is 100% clean.
I cleaned the craft and laid the towels under it, ran for a bit, gave it some RPM and oil collects almost under the oil-filter area. I cleaned it some more and going to let it dry now and see if I can point out the problem. Also, I think I saw some oil on top of the block, away from oil filter towards the front of the craft and around oil-pressure switch. I also looked at repair manuals and saw a radiator on the same side where there appears to be an oil leak.
As I said, I am planning to let it dry of water, shove as many towels as I can in cavities and try to point out the problem but I was hoping someone might be able to point me in the right direction of what I should look at first or what might be more likely...
I can not say exactly how fast the oil depletes but it is not a tiny leak, that is for sure. After maybe.....1 minute of running, approximately 1/3 of a paper towel was in oil.
Thanks a lot in advance and happy new year
p.s. the craft has been sitting for about 6 months in pretty hot weather, under cover, but was washed down before storage (if this at all helps)
