Would like to ask the forum before I start to dismantle things. Just bought a 2009 RXT 255 with 17 hrs on the clock.
Had driveshaft and carbon seal replaced before I bought it.
Overall super clean appearance.
First time I had it docked over night it took in a significant amount of water while sitting. When I got going (before realizing there was water in the hull) I got IBR error codes and I assume it was due to moisture and the module being soaked in water. That is how I discovered water in the hull.
I trailer the machine , filled the hull up with water and discovered a leak between the ride plate and inlet grate (photo attached).
Is this a common problem?
Anyone experience this?
Can I just remove the inlet grate and seal it? I hope the ride plate does not need to be removed as it sounds like a true PITA.
Any advice or input much appreciated.
