Getting these codes with the machine under load. Ok on trailer. Not so much in the water.
codes come and go.
I know the system is very finicky.
I charged battery, checked all connections, fuses. I looked at the IBR gate and it all moved freely. I took it off the machine planning to remove the IBR actuator and it turns out the white plastic friction sleeves are all worn out. Could this be the issue?
it is a but puzzling as the machine has 17 hrs on it. That much wear in 17 hours?
codes come and go.
