Well,,,
If you have run the engine it is HIGHLY likely that you have created damage. In a nutshell, coolant is not compressible. As a result, when you put it into the intake and it makes it to the cylinders and the valves close,,, it is now in the combustion (aka compression) chamber.
So,,, if the engine locked up and did not turn over you may be safe. Remove all of the plugs and crank the engine. But even then, crank it for like a quick second at a time as the water will be like a jet coming out of the spark plug hole.
If the engine did turn over with water in it, and there was more than a small amount of water (as a small amount might pass as there is air in the chamber that can compress and take up the room of the water), then you will likely have damage. Could be a valve, head, or head gasket. Officially you could have a block issue that that is VERY rare as the water is pushed to the top of the block via the piston.
Lastly, if you put the coolant in and THEN realized your mistake. Use tubes to siphon out the water. In a perfect world, turn the ski upside down to further get the water out. If you cannot do that, remove the plugs and LIGHTLY crank the engine.
Once you do get all the water out, assuming there is no damage. You want to run the engine ASAP and let the oil inside the engine do its job. You will need to do an oil change immediately as well as you want to remove the residual coolant from the engine so that once it sits it does not cause a corrosive situation..
