Automatic electric bilge pumps.... Good Idea! :thumbsup:
Wire the automatic wire directly to the battery so it's on in automatic mode all the time (use an inline fuse of course, 20 amps). Put a manual 2 position rocker switch in your glove box so you can test pump operation periodically... I put an automotive lighted rocker switch in my glove box. Academy stores have a SeaSense 600 gph auto bilge pump with integrated float switch for like $29, it has a very small footprint and very good water flow. I highly recommend it!
Have you run them on the trailer alot? Run time out of water, even if hooked to a waterhose, should not exceed 5 minutes or so... the carbon ring get's hot running dry, it's normally cooled by the waterflow going thru the pump but the water hose does not cool the seal at all. They should have lasted ALOT longer than this, my '06 RXT with 73 hrs now is still running the original carbon ring with no problems whatsoever.
- Michael
