I have a 2009 Challenger 180 with 56 hours on it, been a great boat!! I pulled it out to get it ready for the season, has a brand new battery and had the charge topped off the other day. When I turn the power switch on the gauges go through the "check" just fine. When I attached the lanyard I get one long beep and nothing when I press the start switch. Looking through the posts I've determined it's one of the following:
1. Dirty key/ DESS post - is there anything special to cleaning these? Mind you they don't appear dirty or corroded.
2. No communication to MPEM - where is the MPEM located?
3. Bad ground to battery/ engine - the ground does not appear corroded or bad, but I'll clean it tonight
4. Bad ground to MPEM - where is this ground located?
5. Bad Ground at starter - I need to locate the starter and check the ground
Another clue to me it's a grounding issue is that for the past two years whenever we would shut down to anchor or stop, I would pull the lanyard. However, the gauges would occasionally "check" like I had just turned the power switch on, this would happen unless I shut the power switch off. I'm open to other ideas as well, thanks.
CDR D
CDR D
