I am looking to sale my 2008 Seadoo WakeEdition (HyperLite Demo Package) ski. The only reason why I am considering in selling this boat is to get back into a wakeboard boat. The boat has an extended (transferable) WARRANTY until 04/26/2013!!! She is the 215hp superchaged and comes with trailer, and cover. It also has the wakeboard rack and ballast system. There is 120 hours on the boat currently. She has never seen salt water. Her top speed at wide open throttle with 1 person is around 63mph. There has been NO modifications made to the boat other than the hull graphics package. She has PLENTY of power to pull a slalom skier as well as a wakeboarder with full ballast.
http://photobucket.com/seadoo this is a link to pictures of my ski.
I have all the Warranty paper work as well as all general service records (oil changes, supercharger services, etc)
This boat has always been adult driven and has been primarly used in tournaments and demo shows. I even have pictures of Shuan Murray(Wakeboard Pro) on this boat giving wakeboard instructions.
Wake Edition Specs
Engine Type: 215 hp Supercharged Intercooled Rotax 4-TEC
Intake system: Supercharged with intercooler, 52mm throttle body
Bore x stroke: 100mm x 63.4mm
Displacement: 1494cc
Compression ratio: 8:4:1
Cooling: Closed-loop cooling system
Fuel type: Premium unleaded
Length: 130.0 in. (331.0cm)
Width: 48.0 in. (122.0cm)
Height: 47.2 in. (120.0cm)
Rider Capacity: 1, 2 or 3
Fuel capacity: 15.9 US gallons (60L)
Storage capacity: 34.3 US gallons (129.8L)
Propulsion system: BlANK
BLANK : Sea-Doo Direct Drive
Jet pump: Aluminum, axial flow, single stage, large hub with 10-vane stator
Transmition: Direct drive, forward/neutral/reverse and high performance electric VTS
Impeller: Stainless steel
Ignition: Digital inductive
Starter: Electric
Battery: 12 volt
Type: Modified-V, composite
Color: Deep Black/Viper Red
Speedometer (Information Center): Standard
Tachometer (Information Center): Standard
Fuel gauge (Information Center): (Information Center)
High performance VTS: Standard
Information Center (20 functions): Standard
D.E.S.S.: Standard
O.P.A.S. system: Standard
Sea-Doo Learning Key: Standard
Reboarding ladder: Standard
Double density comfort hand grips: Standard
Wide handlebars: Standard
Reboarding deck pad: Standard
Wake Package (Standard): Standard
New ballast system
New high performance electric V.T.S.
Retractable ski pylon
Removable wakeboard rack
Watertight, removable storage bin
Convex mirrors
http://www.personalwatercraft.com/manufacturers/sea-doo/2008-seadoo-wake-edition-681.html
Serious Calls only Please 706-831-1924
Asking 8,000 obo.
Wake Edition Specs
Starter: Electric
Battery: 12 volt
D.E.S.S.: Standard
New ballast system
Convex mirrors
Asking 8,000 obo.
