2008 RXT clean Impeller / Jet Pump ?
Why do you want to clean the pump?
remove opas linkage bolts. remove steering linkage bolt. remove reverse bucket spring. Set all nuts and bolts aside. remove 4 steering nozzle bolts and washers. remove nozzle. disconnect the opas hose from the top of pump or the body...ie loosen worm clamp disconnect hose. remove 4 nuts and washers from pump mounting bolts.
carefully slide entire pump from bolts...at this same time you'll be removing the prop from the drive shaft. once free...support the drive shaft with...tin can or other soft block.
Place your prop removal tool into vice...place pump assembly onto the tool. remove three bolts from pump cone...tap on the cone with a rubber mallet. set cone aside. with big azz hex ...12mm I think...loosen counter clock wise...it's on tight. Once loose...pull pump off remaining prop on the removal tool.
Clean away.
Before you reassemble...fill cone with clean grease.
