2008 RXP 255 Hesitation Issue
OLR
I have a 2008 RXP 255 and it hesitates at full throttle. You can see the tach job from 8200 rpm to 7500 rpm.
If I give 1/2 throttle, it will cruise to 65+ mph with no problem. It is only having problem if you give full throttle.
I have changed the plugs, fuel filter, coil packs and inter cooler.
Any assistant would be greatly appreciated.
thanks,
OLR
I have moved this to the 4-tec forum and left a 30-day redirect for you so you can easily find it..
thanks,
OLR
So...you're cruising along at wot and it happens then goes back up to 8200...or it happens as soon as you hit the throttle...then climbs up to 8200?
SC Slip ?
The super charger was rebuilt last year.
it feels like when you hit a rev limiter and it bonces in a car.
I recently pulled the several codes off the unit and cleared them. But the problems is the same.
P0463
P0513
P1544
P1520
P0562
P0600
It will go up to go to 8200 RPM and starting bouncing. similar to a miss and you can see the tach jumping form 8200 to 7500
Who rebuilt it? Check for loose or disconnected wires/sensors. Something about the symptoms reminds me of a knock sensor issue. Will check around.
Possibly an intake hose collapsing under high boost.
With the seat off...remove the air intake hose from the sc. Take it for a spin and see if symptoms reoccur.
Thank you for your comment. I will try it this weekend and let you. If you think of anything else, please let me know.
