SeadooLake
We have an 08' RXP which I picked up as a "Project Ski" knowing it would need some work. Previous Owner didn't know much about it, but his "Friends" would come help to fix it. Initially I put a New Battery in and it would crank over, but not start. I check for spark it was intermittent, and the fuel injectors were not opening. I disconnected A & B connectors off the ECM and and re connected and the Fuel Injectors were now active. but still no start. When the key is placed on the DESS Post I would get the welcoming 2 beeps, then one long beep.
I noticed quickly that if I took the key off the DESS Post, I could still crank the motor which was odd, but again no start. Thinking the main power relay was the issue, I pulled it off and found the previous owner wired pins 85 & 86 together, and pins 87 & 30 together. I swapped out the Power Relay with a new one, and now the ski is completely un responsive. Any suggestions on how to get this ski to power back up? Thank You
