Beach Addiction St Kitts
hey all
When I rebuilt my jet pump with all new parts after the impeller bearings went, I didn't put a plug into the top where it sucks water from the jet pump because the old one got ruined and the new one was missing that part. When I had issues with the exhaust over heating to the point that the rubber sleeve started melting and smoking inside the ski, I was told to check the seal where the jet pump mounts onto the ski as a bad seal may be causing the issue. Figured it was the missing plug. Got it and exhaust seemed to stay cool to the touch so figured I was losing the suction and now it was sorted. I do flyboarding and when I got the hose sucked into the intake grate and around the shaft, I had to take off the jet pump to get it out. After reassembly same exhaust overheating issue. Figured I'd put the jet pump on badly and lost the seal that I was originally warned about so I took it off, cleaned it up and reattached jet pump. exhaust pipe still seems to be getting too hot idling so took apart and reassembled jet pump again... so that's twice now i've take off the jet pump and reassembled it hoping to get a better seal to sort the overheating issue. still have problems. inspected the exhaust tank thing and found some sand in it. A lot of sand flushed out when i flushed it on land and i figured it had just been washed in from the outside through the back of the ski. Perhaps sand has been sucked through the whole engine though where it's sucked in from jet pump and is clogging it up. Only explanation I can find why I would still have overheating when in water but not when flushing connected to a hose is something in that line is blocked... Still dont understand water cooling system though because what appears to be water coming into the metal pipe from the exhaust... and only going as far as the exhaust... how does that water flush back up along exhaust manifold cooling chambers and intake manifold cooling chambers if water is only introduced on the way to the exhaust cooling tank... help please.... can i connect a fresh water hose pipe directly to the hose that runs up to serve the intake manifold, rather than to the flushing connection? the jet pump provides the force of water to pump water through the water cooling system, but I am concerned that providing not enough or too much water using a hose pipe may or may not damage it? Why doesn't the flushing connection just join the water line from the jet pump comes into the ski and follow the same exact route... like what i want to do to try flush it.
on another side note, when i reattach my jet pump, the splines area seems to have water in it. the boot is prob not sealing properly and wants replacing...
first major thing is getting the water cooling sorted... live on a small caribbean island with no seadoo aware mechanics so i have to do it myself... HELP PLEASE!!
