Casey_Martin3
I'm working on a 2007 RXT 215 supercharged. After a water test, the result was as followed.
Ski starts up well, two beeps when key placed on dess post with no additional beeps. Ski idles fine and sounds good. When throttle is applied response is okay but not as strong as I feel it should be (keep in mind I have never ridden the ski at full power). The ski gets going and the max speed I can achieve is 30 mph before I hear the engine sound like it is hitting a rev limiter or missing, almost like a spark cut. However I have no idea what the engine RPM is because of a faulty gauge cluster. I am using the full power key, not learner key
I have
- replaced both fuel filters
- replaced spark plugs
- inspected wear ring, doesn't look good but ski gets going decently which is why I don't think it's the ring.
I am planning to check fuel pressure, I am open to other suggestions of things that I should check
I have
