2006 Speedster 430 Wake Ballast pump fused?
Rod E
I have a 2006 Speedster 430 Wake. The ballast pump motor works fine but am not getting power to the switch. Is there a fuse for the ballast pump. I have had no luck with the searches I’ve checked on. Any help would be grateful.
I will answer my own question! Yes there is a fuse! I traced the wires from the ballast pump to the the pump switch. There is a single fuse which along with several other single fuses that hang from several wire looms (unmarked)in the engine bay.(starboard)Sure enough when I removed it it was blown. I replaced it and it works fine. Thanks but no thanks for any help out there!
