Hi, thanks for reading. I recently purchased a pair of 06 GTX's, one is supercharged (115hrs) and one is not (75hrs). Some interesting points:
- The impeller one the SC ski is pretty nicked up. I had to pull some rocks out of the back pf the pump - I am guessing PO ran it in shallow water.
- The non SC ski comes out of the hole faster than the supercharged one. The SC can gain some ground on the top end, but nothing impressive. Maybe due to above?
- The SC ski uses more fuel than the non SC ski. 3 days out and fuel consumption was 8g and 6.5g, 4g and 3g and 5g and 5g, respectively.
- The instrument cluster is dead on both skis. I have checked fuses and done a basic visual on wiring, nothing obvious.
- The SC skis gives me the occasional long beep when running. At first I thought it was only when running wide open for periods of time, but now it seems more random than that.
- The knock sensor and exhaust temp errors always occur together.
- Engine compartment temps between the two seem pretty similar.
- The SC always has more warm water in the bilge after going out.
- Both Ski's run great and pull like a mule.
- I am running 93 octane fuel.
- I bought Candoo pro.
- "Last Serviced By" shows SBT, makes me wonder if the engine or MPEM was replaced.
I am attaching the Candoo report on the SC ski. I didn't have a chance to hook up to the other other ski yet. The things I am wondering about are:
- is the SC ok to ride, even though its throwing the error code?
- what should I address first? I want to replace the clusters, mostly so I can monitor fuel level.
- is it worth replacing the impeller?
I can't seem to upload attachments, so I uploaded the Candoo report with error codes below:
https://photos.google.com/share/AF1...?key=ckZoWDhCX1R4YXpvUkRTSDNNX1JjQ3ZCZllxWEJB
