68ragtop
Next up project is a 2006 215 4tec rebuild & I am looking for some confirmation on internals as I am aware this is the year things started to change.
this engine does not have the tops valve setup like the early years. its has just the oil separator/pump with the square oil screen & the plastic fill tube. Does this make it the late 2006 style? I think it might, but I am not sure.
Also, as far as crankshafts go I know there are several numbers from 2002-2006 & most will interchange from a fitment perspective, but I think there is something different with the alignment for pin bore for setting #3 at TDC? & possibly materials used I noticed some cranks looked to have heat treated rod journals & some of the early ones do not. Is this a strength difference & can a std 155 crank withstand the extra 60Hp? Or are these cranks just two different animals?
68RT
68RT
