jrsharpebc
Hello all,
I've been reluctant to post up but I'm kind of at my wit's end. I've been chasing a few issues on my 06 Challenger for a couple years and have solved all of them but this final one: hard starting when warm or hot. I've read every "hard starting" post on here and some of them are close in similarity, but their solutions are things I've already tried. I took a video last year (August, I think), with a voltmeter on the battery: Here. This happens consistently and is very repeatable.
Things I have done/troubleshot in 2020 include:
- installed new battery, 950CCA (old one was on its 4th season)
- cleaned all grounds (block & battery)
- cleaned all +12 (battery, switch & starter relay)
- new coils
- dealer checked fuel pressure and pump, apparently is OK (disconnecting fuel lines is beyond my comfort...)
She starts perfectly when cold (sitting all night), and runs perfectly in either scenario (ie either from a cold start or after a hard hot start it chugs to life and shows no running issues afterward).
The only things I have not done are checking voltage drop across the relay, checking voltage at the actual starter and pulling the starter (worn brushes??). The first 2 are on my list this year once things warm up a bit more. I'm also tempted just to buy a new relay, I've read these things just go bad over time...and they're relatively cheap. CanDoo is on my purchase list this year also.
So I turn to the wisdom of the forum...and I know it is impossible to diagnose over the internet... but any insight will be appreciated.
Thank you in advance.
John
- new coils
John
