Folks
Could really use some help. My 2005 Utopia 200hp merc efi m2 I think it says on there. It sat for about 2 years. The other day went for a ride and the engine sounds like it want to shut down or starving for fuel. It will just barely come up on plane. If you apply full throttle from a stop it will rev up completely and in 3 seconds later it want shut down or sounds like it is breaking up. I have replaced all the fuel after draing the tank completely and used fresh fuel. I have installed new spark plugs and fuel/water seperator. I have check the fuel pressure and air pressure at the injector rail giving me about 80 psi fuel and just about equal for the air pressure. The pressure seems to hold when attempting to raise the rpm and remains at this pressure even when the engine starts to act up about 3500 or a little more. The engine starts with no problem, idles with no problem and runs very smooth unless trying to go about 3500 or above. A mechanic attached a computer to the engine. It has 123 hours and he checked all the cylinders to confirm they were firing and said all was good. It feels like a starvation of fuel. Maybe i'm wrong and its an ignition problem.
But i would appreciate anyones input or if anyone experienced this sort of issue with some feedback
Thanks Carl
Thanks Carl
