2005 Seadoo gti rfi le 5000rpm
kluttrell169
Just rebuilt motor cleaned race valves. But didn’t replace. Unit is still on first tank of premix fuel and oil tank filled.
however I’m not able to brake past 5000 rpm and doesn’t seem to have take off power and loses power in turns.
hooked my candoo up cleared codes today and went out on the lake no change. But maintenance light is not on. Some I don’t think it’s restricted. However I’m new to seadoo and the candoo tool
As POPPS said, "fuel."
Check your rave solenoid and make sure the raves are free to move. You can blow on the hose or hook up a hand pump. You can test the rave solenoid by applying voltage to it. 5K RPM is definitely Rave territory.
The Candoo doesn't help much with the RFI. I always do the tests listed in the manual and verify each component is good.
