2005 Islandia Problem - Air Compressor?
Got towed off the lake today.....my 2005 Islandia shut down. Thought I had a bad drive belt but the pulley lifted right off the air compressor housing. Has any one ever seen this happen before. I don't even know what the air compressor does? I am a jet drive idiot. Need some help.
First.... I'm assuming you have a 250 Optimax engine?
I can't say I've heard of someone saying that they lost their compressor pulley. It's held on with a few 6mm bolts. Did they shear off... or are they missing? OR... did somethign else break?
Anyway... the 250 Opti engine is a Di system. SO... it uses air pressure, along with fuel pressure, to inject fuel under high pressure, directly into the combustion chamber. It won't run without the air.
Post a pic if something else broke.
Thanks for the information.
If there is a shaft inside the compressor assembly i think it might have snapped...
I have pictures but for some reason they will not load on the forum....is there some trick to posting pictures
There is a shaft for sure,,
They experimented with this fuel system in the automotive world and it didn't pan out.
But,,, they did keep and modify the air injection pump to help with emissions.
They fail often. In the auto world there is no filter system for the pump, ( I have no idea if this is the case with the seadoo boats).
Going down the road the compressor/air pump sucked in all the dirt and dust in the air. It destroyed the pumps to the point they would seize. Once seized the pulley or the belt had to give as it is still being driven.
In the case of your boat, you NEED this pp to run where in the automotive world it is not needed to run.
Figure out if it is seized not the bolts came loose.
If the air compressor seized do you know if it is possible to just replace the shaft or do I have to replace the entire air compressor?
If they are like automotive air injection you will need to replace it. The vanes on inside seize up and pretty much destroy itself.
Again, I do not know if our boats are the same build as automotive, but I would speculate they are.
Joe is talking about the old "A.I.R." pumps (Air injection reaction). It was some crazy thing that an engineer thought up, in the 70's. The idea was, if you inject fresh air into the exhaust... it would help run off any leftover hydrocarbons. In reality... all it did is add complexity, and dilute the exhaust (for an emission test)
As far as a Di system in the automotive world... it's just now starting to catch on. (15 years after the boat and PWC world discovered it) Nissan is using it on a lot of their engines.
Anyway... as Joe said... it's not running without it.
There shouldn't be a trick to uploading pics. But, I personally find it easier to just load them on a site like "PhotoBucket", and then use the "IMG" tag to link them back.
On the air pump, the entire crank unit will come out. There should be 4 bolts around the flange... and you can wiggle it out as a unit. Once it's out... you can see if there is any damage inside.
The crank is sold as a unit... but I think there is a snap ring, that will hold the hub onto a tapered shaft, with a key. Unfortunately... since it is sold as a unit... I can't tell. But, in my years of playing with outboards, I can't say I've heard of the crank assembly going bad. Normally, the valve system gives out, and you lose pressure, or the pump simply wears out.
