Hi, I just bought a 2005 Islandia Optimax 250 which will not start on its own.
The boat was bought at an auction so there isn't much in terms of history from the previous owner. The two noticeable things that give clues are: registration dating back to 2010, and an oily residue covering the bottom half of the engine bay/bilge likely from some kind of partial submersion.
The engine cranks but will not start. I can get the boat started by using starting fluid (OH NOES! I swear I didn't know before today that is a no-no and I am hoping I didn't cause any permanent damage). The other method that I got the boat started was to crank it until I heard some ignition then quickly throw it into Forward gear and apply more throttle. Once started the engine seems to be running fairly smoothly.
What I have done to try and mitigate the problem:
Admittedly I have not done a lot of searching for possible culprits. But I was going to check cylinder compression and fuel pick up pump vaccum and pressure next.
The Factory Service manual also suggests checking voltage while cranking (should be above 8VDC), checking air pressure at cranking.
I'll take any and all suggestions on the appropriate course of action to get it to start.
- drained/siphoned the gas out of the tank and replaced with new gas (treated with Stabil marine stabilizer) checking the pick up screen for any obstructions
 - drained the vapor separator
 - replaced inline fuel filter at the pick up pump
 - replaced fuel water separator adding the recommended mixture of 2 cycle oil, and Quicksilver fuel additives as listed in Service Manual.
 - checked fuses
 - replaced spark plugs with factory recommended NGK ones (the existing ones where a mixed bag of autolite and ngk)
 - replaced air filter (mounted in air intake housing)
