2005 Islandia Opti 250 speedometer
75sausage
Looking to replace a faulty speedo on my Islandia. Needle is pegged on 65mph and will not budge. OEM part is $775, ouch.
Any suitable replacement options?
You can replace it with a generic boat speedo, or you could add the "Smartcraft" gauges to that engine.
a few years ago i got a speedo made by Faria from greatlakesskipper.com for $79. even had "bombardier" on it. very close to oem look. My order eceipt says their pn is 100477.
Thank you AirSniper, but I already placed an order for a generic Faria gauge.
As far as the Smartcraft gauges. I noticed the Merc Monitor install in the sticky which seems like it's straight forward. I am not crazy about the square monitor but the SmartCraft SC1000 Tachometer seems like a worth addition. Of the top of your head, Dr Honda, would that require the same type of harness (879982T20 CAN harness) as mentioned in the sticky or it's a completely different install?
I added the SC1000 and it does require an $85 harness. I am very happy with it as it shows a bunch of parameters. The sticky was very helpful.
