I bought a used 05 GTX SC and previous owner said to always pull the 30A fuse because they all drain the battery. Seems weird but I notice once I install the fuse, the oil separator coil clicks/pulls in every 10 sec or so, and never seems to stop (which I'm sure is/was draining the battery), though I'm not sure what happens when its running. I tried unplugging the TOPS sensor and it didn't change, but when I ohm the TOPS sensor, it doesn't read 35 ohm in "up" position, though it does read 10k when down--making me think its bad. Any thoughts if the two are related? The ski seems to run fine (pulls 7600 rpm) so for some reason, it doesn't think its rolled-over, which I thought is what the TOPS should do if reading 10k.
