2005 3D Wont Turns over (sparks fine, Motor Starts I Think)
Declan
Hey Everyone
Just started ski for first time this year we had a colder than usual winter, brrrrrrr :hat:
I can't seem to get my Seadoo 3d 2005 rfi started, ive charged the battery changed the plugs and getting spark
when i remove plugs it turns over put no fuel or liquid is coming out,
anybody any ideas
Just an update i checked the fuel pump as it looked like i was getting no fuel into engine all was good
also checked pipes to carburetor i read this could get blocked after storage, one was blocked so i cleaned it, should i remove the carb and check for blockages? is it an easy task? i couldnt see the needle valve mentioned in shop manual has any one got pics of it?
i had a quick look and looks like i have to remove the exhaust to fully remove
the Carb
has any one done this before?
Hi Declan, I wouldn't go pulling the carbs off yet. Did you say it turns over
when the plugs are out?? Does it turn over when the plugs are in?
Did you check BOTH fuel filters on the pump? there is one at the bottom which is replaceable and the one at the top is not. If its the one at the top that is clogging, you gots to get a new pump:(
update
brought to dealer all sorted plugged into computer, problem with oil tubes being blocked, he said my model doesnt have carb, is this correct?
Also bleed the pump, is this an easy task for future incase?
Correct, This is an RFI (rotax fuel injected) model. It doesn't have a carburator in the old sense of the word.
